I’ve downloaded the alpine kvm virtual router appliance. And then created a VR. It’s connected to two VNETs. And now how do i use this VR? Defining forwarding rules or dhcp etc?
Forwarding should work out-of-the-box, if you want to place more services in the VR, you need to login and install/confgure them. You may want to use context to automate this process…
So, if I get it right, there isn’t any (nat, dhcp, etc) configuration through sunstone (and wont be?) And so, it’s basically same with having a custom fw&router VM inside. It’s just moved under a new title with a new tag.
