Integration with AD
My original post was closed - Active Directory integration working in 2025?
We’ve spent some time going through ALL ON, following the process of how ON works, and this was our notes on how we got AD integrated with ON.
OpenNebula Active Directory Integration - Implementation Summary
Objective
Connect OpenNebula 7.0.1 (FireEdge/Sunstone) to Active Directory for user authentication.
Environment
Component Detail
OpenNebula Host opennebula-host.example.ac.uk
AD Domain example.ac.uk
AD Domain Controller dc01.example.ac.uk
OS Ubuntu 24.04.4 LTS
OpenNebula Version 7.0.1
Steps Taken
1. Initial Configuration
  • Backed up original ldap_auth.conf
  • Configured server 1 in ldap_auth.conf with AD server, base DN, service account and group restriction
2. Service Account Creation
  • Created svc-opennebula in CN=Managed Service Accounts,DC=example,DC=ac,DC=uk
  • Account requires read-only access to AD directory
3. AD Group Creation
  • Created CN=OpenNebula Users,OU=Groups,DC=example,DC=ac,DC=uk
  • Group scope set to Domain Local (to allow cross-domain trust members)
  • Added test user and cross-domain user as members
4. LDAP Connectivity Testing
  • Used ldapsearch to verify connectivity on port 389
  • Confirmed service account could bind and search the directory
  • Confirmed test user existed and was in the correct group
5. Issues Encountered & Resolved
Issue 1: Authentication driver 'default' not available
  • Cause: Normal Sunstone health check — not a real error
  • Resolution: Ignored, not related to LDAP auth
Issue 2: Request timeout
  • Cause: Multiple contributing factors:
    • :timeout setting in ldap_auth.conf was never passed to Net::LDAP object in ldap_auth.rb
    • :disable_referrals not implemented in the Ruby library
    • TIMEOUT in oned.conf was commented out
    • mapping_generate making API callback to OpenNebula causing deadlock
  • Resolution:
    • Added ops[:timeout] and ops[:referrals]=false to ldap_auth.rb
    • Set TIMEOUT = 60 in oned.conf
    • Set :mapping_generate: false in ldap_auth.conf
Issue 3: memberOf attribute not returned
  • Cause: Service account did not have permission to read memberOf attribute on user objects
  • Resolution: Ran on DC:
powershell
  dsacls "OU=Managed,DC=example,DC=ac,DC=uk" /I:S /G "example\svc-opennebula:RP;memberOf;user"
Issue 4: mapping_generate deadlock
  • Cause: The mapping_generate function makes an API call back to OpenNebula during authentication, causing a deadlock/timeout
  • Resolution: Set :mapping_generate: false in ldap_auth.conf
Issue 5: Users must be pre-created
  • Cause: Unlike old Sunstone, FireEdge does not auto-provision LDAP users on first login
  • Resolution: Users must be created manually before first login:
bash
  oneuser create USERNAME "placeholder" --driver ldap
Final Working Configuration
/etc/one/auth/ldap_auth.conf
yaml
server 1:
    :auth_method: :simple
    :host: dc01.example.ac.uk
    :port: 389
    :timeout: 30
    :user: 'svc-opennebula@example.ac.uk'
    :password: 'SERVICEACCOUNTPASSWORD'
    :base: 'DC=example,DC=ac,DC=uk'
    :group: 'CN=OpenNebula Users,OU=Groups,DC=example,DC=ac,DC=uk'
    :user_field: 'sAMAccountName'
    :group_field: 'member'
    :user_group_field: 'dn'
    :rfc2307bis: true
    :mapping_timeout: 300
    :mapping_filename: server1.yaml
    :mapping_key: GROUP_DN
    :mapping_default: 1
    :disable_referrals: true
    :unbind_anon: true
:order:
    - server 1
### `/etc/one/oned.conf` changes
TIMEOUT = 60
/usr/lib/one/ruby/opennebula/ldap_auth.rb patch
Added to the initialize method after the existing ops[:encryption] line:
ruby
ops[:timeout]=@options[:timeout].to_i if @options[:timeout]
AD permissions
powershell
Ongoing Administration
Task Command
Create new LDAP user oneuser create USERNAME "placeholder" --driver ldap
Switch existing user to LDAP oneuser chauth USERNAME ldap
Add user to AD group Add to CN=OpenNebula Users in AD
Test LDAP connectivity ldapsearch -x -H ldap://dc01.example.ac.uk -D "svc-opennebula@example.ac.uk" -w 'PASSWORD' -b "DC=example,DC=ac,DC=uk" "(sAMAccountName=USERNAME)"
Verify memberOf readable ldapsearch -x -H ldap://dc01.example.ac.uk -D "svc-opennebula@example.ac.uk" -w 'PASSWORD' -b "DC=example,DC=ac,DC=uk" "(sAMAccountName=USERNAME)" sAMAccountName memberOf dn
Security Notes
  • Use a dedicated read-only service account for LDAP binding
  • Set the service account password to never expire
  • Grant only the minimum permissions required (memberOf read on user objects)
  • Store the service account password securely — not in plain text if possible
Hopefully my notes, will help someone in the future, now we fully understand the “code” behind ON !
