Is possible to add/modify security groups to a running VM?
After a creating a VM whether it is possible to add/modify a security groups using Opennebula XMl RPC 5.2?
I’m also very interested in knowing if it possible.
Yes, you can. But you can also use higher level APIs (like the Ruby OCA) and it will abstract you part of the complexity.
