Below is my econe-server.log
econe.conf…
Copyright 2002-2017, OpenNebula Project, OpenNebula Systems
Licensed under the Apache License, Version 2.0 (the “License”); you may
not use this file except in compliance with the License. You may obtain
a copy of the License at
http://www.apache.org/licenses/LICENSE-2.0
Unless required by applicable law or agreed to in writing, software
distributed under the License is distributed on an “AS IS” BASIS,
WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
See the License for the specific language governing permissions and
limitations under the License.
Server Configuration
Directory to store temp files when uploading images
:tmpdir: /var/tmp
OpenNebula sever contact information
:one_xmlrpc: http://localhost:2633/RPC2
Host and port where econe server will run
:host: localhost
:port: 9999
SSL proxy URL that serves the API (set if is being used)
#:ssl_server: https://service.endpoint.fqdn:4567/
Auth
Authentication driver for incomming requests
- ec2, default Acess key and Secret key scheme
- x509, for x509 certificates based authentication
:auth: ec2
Authentication driver to communicate with OpenNebula core
- cipher, for symmetric cipher encryption of tokens
- x509, for x509 certificate encryption of tokens
:core_auth: cipher
Log
Log debug level
0 = ERROR, 1 = WARNING, 2 = INFO, 3 = DEBUG
:debug_level: 3
Resources
Cluster associated with the EC2 resources, by default no Cluster is defined
#:cluster_id:
Datastore in which the Images uploaded through EC2 will be allocated, by
default 1
#:datastore_id:
Include terminated instances in the describe_instances xml
:describe_with_terminated_instances: true
Terminated VMs will be included in the list
till the termination date + TERMINATED_INSTANCES_EXPIRATION_TIME is reached
:terminated_instances_expiration_time: 900
[DEPRECATED] File based templates
Use former file based templates for instance types instead
of OpenNebula templates
:use_file_templates: false
VM types allowed and its template file (inside templates directory)
:instance_types:
:m1.small:
:template: m1.small.erb
Elastic IP
VirtualNetwork containing the elastic ips to be used with EC2. If no defined
the Elastic IP functionality is disabled
#:elasticips_vnet_id:
Script to associate a public IP with a private IP
- arguments: elastic_ip private_ip vnet_template(base64_encoded)
:associate_script: false
Script to disassociate a public IP
:disassociate_script: false
EBS
FSTYPE that will be used when creating new volumes (DATABLOCKs)
:ebs_fstype: ext3
-------------------------------------END----------------------------------------------------------
I am running ec2 server from the same system as oneadmin. Any idea how do I solve this?
