Keep snapshot after reboot
Shortly after I have created a new VM, I took a snapshot of it.
But now I just noticed, that the Snapshot is not showing up anymore, although as you can see in the log, the snapshot has been successfully created.
Did I do something wrong?
Edit: Looks like Snapshots are not persistent, can I somehow change this?
Thanks!
Fri Aug 10 15:43:14 2018 [Z0][HKM][I]: Command execution failed (exit code: 1): /etc/on-hooks/add_dns 3
Fri Aug 10 15:43:14 2018 [Z0][HKM][E]: Error executing Hook: mail: -.
Fri Aug 10 15:43:41 2018 [Z0][VM][I]: New state is ACTIVE
Fri Aug 10 15:43:41 2018 [Z0][VM][I]: New LCM state is PROLOG
Fri Aug 10 15:43:42 2018 [Z0][VM][I]: New LCM state is BOOT
Fri Aug 10 15:43:42 2018 [Z0][VMM][I]: Generating deployment file: /var/lib/one/vms/3/deployment.0
Fri Aug 10 15:43:42 2018 [Z0][VMM][I]: Successfully execute transfer manager driver operation: tm_context.
Fri Aug 10 15:43:42 2018 [Z0][VMM][I]: ExitCode: 0
Fri Aug 10 15:43:42 2018 [Z0][VMM][I]: Successfully execute network driver operation: pre.
Fri Aug 10 15:43:43 2018 [Z0][VMM][I]: ExitCode: 0
Fri Aug 10 15:43:43 2018 [Z0][VMM][I]: Successfully execute virtualization driver operation: deploy.
Fri Aug 10 15:43:43 2018 [Z0][VMM][I]: Successfully execute network driver operation: post.
Fri Aug 10 15:43:43 2018 [Z0][VM][I]: New LCM state is RUNNING
Fri Aug 10 15:48:47 2018 [Z0][VM][I]: New LCM state is HOTPLUG_SNAPSHOT
Fri Aug 10 15:48:48 2018 [Z0][VMM][I]: VM Snapshot successfully created.
Fri Aug 10 15:48:48 2018 [Z0][VM][I]: New LCM state is RUNNING
Fri Aug 10 16:22:45 2018 [Z0][VM][I]: New LCM state is SAVE_STOP
Fri Aug 10 16:22:50 2018 [Z0][VMM][I]: /var/tmp/one/vmm/kvm/save: line 58: warning: command substitution: ignored null byte in input
Fri Aug 10 16:22:50 2018 [Z0][VMM][I]: ExitCode: 0
Fri Aug 10 16:22:50 2018 [Z0][VMM][I]: Successfully execute virtualization driver operation: save.
Fri Aug 10 16:22:50 2018 [Z0][VMM][I]: Successfully execute network driver operation: clean.
Fri Aug 10 16:22:50 2018 [Z0][VM][I]: New LCM state is EPILOG_STOP
Fri Aug 10 16:22:50 2018 [Z0][VM][I]: New state is STOPPED
Fri Aug 10 16:22:50 2018 [Z0][VM][I]: New LCM state is LCM_INIT
Fri Aug 10 16:23:13 2018 [Z0][VM][I]: New state is PENDING
Fri Aug 10 16:23:42 2018 [Z0][VM][I]: New state is ACTIVE
Fri Aug 10 16:23:42 2018 [Z0][VM][I]: New LCM state is PROLOG_RESUME
Fri Aug 10 16:23:42 2018 [Z0][VM][I]: New LCM state is BOOT_STOPPED
Fri Aug 10 16:23:43 2018 [Z0][VMM][I]: Successfully execute transfer manager driver operation: tm_context.
Fri Aug 10 16:23:43 2018 [Z0][VMM][I]: ExitCode: 0
Fri Aug 10 16:23:43 2018 [Z0][VMM][I]: Successfully execute network driver operation: pre.
Fri Aug 10 16:23:44 2018 [Z0][VMM][I]: /var/tmp/one/vmm/kvm/restore: line 43: warning: command substitution: ignored null byte in input
Fri Aug 10 16:23:44 2018 [Z0][VMM][I]: ExitCode: 0
Fri Aug 10 16:23:44 2018 [Z0][VMM][I]: Successfully execute virtualization driver operation: restore.
Fri Aug 10 16:23:44 2018 [Z0][VMM][I]: Successfully execute network driver operation: post.
Fri Aug 10 16:23:44 2018 [Z0][VM][I]: New LCM state is RUNNING
Fri Aug 10 16:26:17 2018 [Z0][VM][I]: New LCM state is SHUTDOWN_POWEROFF
Fri Aug 10 16:26:24 2018 [Z0][VMM][I]: ExitCode: 0
Fri Aug 10 16:26:24 2018 [Z0][VMM][I]: Successfully execute virtualization driver operation: shutdown.
Fri Aug 10 16:26:24 2018 [Z0][VMM][I]: Successfully execute network driver operation: clean.
Fri Aug 10 16:26:24 2018 [Z0][VM][I]: New state is POWEROFF
Fri Aug 10 16:26:24 2018 [Z0][VM][I]: New LCM state is LCM_INIT
Fri Aug 10 16:26:38 2018 [Z0][VM][I]: New state is ACTIVE
Fri Aug 10 16:26:38 2018 [Z0][VM][I]: New LCM state is BOOT_POWEROFF
Fri Aug 10 16:26:38 2018 [Z0][VMM][I]: Generating deployment file: /var/lib/one/vms/3/deployment.2
Fri Aug 10 16:26:38 2018 [Z0][VMM][I]: Successfully execute transfer manager driver operation: tm_context.
Fri Aug 10 16:26:39 2018 [Z0][VMM][I]: ExitCode: 0
Fri Aug 10 16:26:39 2018 [Z0][VMM][I]: Successfully execute network driver operation: pre.
Fri Aug 10 16:26:39 2018 [Z0][VMM][I]: Successfully execute virtualization driver operation: deploy.
Fri Aug 10 16:26:39 2018 [Z0][VMM][I]: Successfully execute network driver operation: post.
Fri Aug 10 16:26:39 2018 [Z0][VM][I]: New LCM state is RUNNING
I think in /etc/one/oned.conf there’s a parameter for that:
VM_MAD = [
NAME = “kvm”,
KEEP_SNAPSHOTS = “no”,
Try setting that to “yes”, restart OpenNebula services and see if it helps.
CU, VMGuy
