Hi there,
Server and nodes are hosted at the CentOS Linux release 7.6.1810 (Core).
$ uname -r
3.10.0-957.10.1.el7.x86_64
When I start VM live migration the bridge interface has entered into the disabled state.
Please find some console outputs/logs.
Before migration:
[sadm@one-kvm-node-02 ~]$ brctl show
bridge name bridge id STP enabled interfaces
br0 8000.0025902dd6fc no eno1
br1 8000.0025902dd6fd no eno2
one-20-0
After starting the migration:
journalctl shows the following messages:
Mar 20 10:25:40 one-kvm-node-02.tsu kernel: device eno2 left promiscuous mode
Mar 20 10:25:40 one-kvm-node-02.tsu kernel: br1: port 1(eno2) entered disabled state
VM log:
Wed Mar 20 10:25:34 2019 [Z0][VM][I]: New LCM state is MIGRATE
Wed Mar 20 10:25:34 2019 [Z0][VMM][I]: Successfully execute transfer manager driver operation: tm_premigrate.
Wed Mar 20 10:25:35 2019 [Z0][VMM][I]: ExitCode: 0
Wed Mar 20 10:25:35 2019 [Z0][VMM][I]: Successfully execute network driver operation: pre.
Wed Mar 20 10:25:40 2019 [Z0][VMM][I]: ExitCode: 0
Wed Mar 20 10:25:40 2019 [Z0][VMM][I]: Successfully execute virtualization driver operation: migrate.
VM has stucked in the MIGRATE status.
To solve this issue I’ve restarted network service:
[sadm@one-kvm-node-02 ~]$ sudo systemctl restart network
And migration process has successfully finished:
VM log:
Wed Mar 20 10:33:10 2019 [Z0][VMM][I]: clean: Executed “sudo ip link delete br1”.
Wed Mar 20 10:33:10 2019 [Z0][VMM][I]: ExitCode: 0
Wed Mar 20 10:33:10 2019 [Z0][VMM][I]: Successfully execute network driver operation: clean.
Wed Mar 20 10:33:10 2019 [Z0][VMM][I]: Successfully execute network driver operation: post.
Wed Mar 20 10:33:10 2019 [Z0][VMM][I]: Successfully execute transfer manager driver operation: tm_postmigrate.
Wed Mar 20 10:33:10 2019 [Z0][VM][I]: New LCM state is RUNNING
Node’s outputs:
br1 8000.0025902dd6fd no eno2[sadm@one-kvm-node-01 ~]$ brctl show
br0 8000.ac162db72720 no eno1
br1 8000.ac162db72721 no eno2
one-20-0
Could you assist is there a VM migration method without restarting the network service?
brg,
Serhiy.
