After deleting a VM, all bridges are removed
Today I have updated my server from 5.10.1 to 6.0.0.2 (passing from 5.10.1 to 5.12.0.4 and, then, from 5.12.0.4 to 6.0.0.2).
It seems all is running fine… but not. All not. I have noticed that after creating a VM and, then, deleting, all my bridges are removed.
Information logged at /var/log/one/oned.log:
Mon Jul 26 19:14:37 2021 [Z0][VMM][I]: Successfully execute virtualization driver operation: cancel.
Mon Jul 26 19:14:43 2021 [Z0][VMM][I]: clean: Executed “sudo -n ip link delete br1”.
Mon Jul 26 19:14:43 2021 [Z0][VMM][I]: clean: Executed “sudo -n ip link delete br2”.
Mon Jul 26 19:14:43 2021 [Z0][VMM][I]: clean: Executed “sudo -n ip link delete br3”.
Mon Jul 26 19:14:43 2021 [Z0][VMM][I]: ExitCode: 0
I have found at /var/lib/one/remotes/etc/vnm/OpenNebulaNetwork.conf that I can set :keep_empty_bridge: false to true… but problem remains (I have restarted opennebula service).
Also, I have reconfigured /var/lib/one/remotes/etc/vnm/OpenNebulaNetwork.conf setting that parameter with “delete” (explained at the top of the file), but now when I delete the last VM bridged to my bridge, this bridge is deleted, but if I instantiate a new VM, bridge is recreated OK… but it has lost its IP address… so… how can I avoid the bridge deleting process???
What can I do??? In 5.10.1 all ran fine…
Thanks.
The VNM drivers are executed on the hosts so most probably you are not syncing the hosts after the reconfiguration?
You could try setting :keep_empty_bridge: false and update the hosts with su - oneadmin -c 'onehost sync --force'.
Best Regards,
finally, I found that there are two files OpenNebulaNetwork.conf:
/var/tmp/one/etc/vnm/OpenNebulaNetwork.conf
I had modified to true one of them… so, now, after modifying both files, bridge is kept after deleting last VM.
Thanks!!
The master file /var/lib/one/remotes/etc/vnm/OpenNebulaNetwork.conf is propagated to the hosts by opennebula when you sync the hosts :slight_smile:
It is a good habit to sync the hosts after altering the files in /var/lib/one/remotes :wink:
Best Regards,
Anton
