We recently had a database corruption, which made it impossible for us to use opennebula. We could not even shutdown VMs. So we decided to rollback the database to a backup. This left a few VMs basically stranded, as they were created after the backup date. That’s no problem, however, they are still listening to their IPs which creates a problem for us, as now two VMs may be assigned the same IP. Opennebula obviously does not know about the orphaned VMs. Can somebody tell me what is the correct way to clear the traces of all old VMs.
When I log into a host I can remove the interface using brctl tools (brctl delif br0 one-328-0) and then I down the interface in the ip utility( ip link set dev one-328-0 down) and delete it afterwards (sudo ip link delete one-328-0).
Is this the correct procedure?
Thanks ![]()
