can I prevent opennebula to remove a bridge when the last VM is shut down ?
In other words, can I manage manually a brigde and just let opennebula add or remove vm interface in it ?
Thanks for help
Thanks for help
You can configure certain aspects of the OpenNebula network stack here. Specifically, you are looking for :keep_empty_bridge:, you need it to be true. The file is /var/lib/one/remotes/etc/vnm/OpenNebulaNetwork.conf in the frontend. Remember to run onehost sync --force in order to sync the file to the virtualization nodes, so the network drivers read the changes.
