I get the User login with LDAP working, but when i try to activate the group membership, login isn’t possible.
My ldap_auth.conf:
user: ***
password:***
host: myhost=
port: 389
timeout: 40
base: ‘dc=sec,dc=t-labs,dc=tu-berlin,dc=de’
group: ‘cn=oneadmins,ou=groups,dc=sec,dc=t-labs,dc=tu-berlin,dcde’
user_field: ‘uid’
group_field: ‘member’
mapping_generate: true
mapping_timeout: 300
mapping_filename: server1.yaml
mapping_key: GROUP_CN
mapping_default: 1
rfc2307bis: false
Ldap Structure:
157 cn=oneadmins,ou=groups,dc=sec,dc=t-labs,dc=tu-berlin,dc=de
2503 cn: oneadmins
2504 objectClass: groupOfNames
2505 member: uid=username,cn=user name,ou=users,dc=sec,dc=t-labs,dc=tu-berlin,dc=de
oned.log:
Wed Feb 27 17:52:19 2019 [Z0][AuM][D]: Message received: LOG I 39 Command execution failed (exit code: 255): /var/lib/one/remotes/auth/ldap/authenticate
Wed Feb 27 17:52:19 2019 [Z0][AuM][I]: Command execution failed (exit code: 255): /var/lib/one/remotes/auth/ldap/authenticate
Wed Feb 27 17:52:19 2019 [Z0][AuM][D]: Message received: LOG I 39 Trying LDAP server server 1
Wed Feb 27 17:52:19 2019 [Z0][AuM][I]: Trying LDAP server server 1
Wed Feb 27 17:52:19 2019 [Z0][AuM][D]: Message received: LOG I 39 (member=username)
Wed Feb 27 17:52:19 2019 [Z0][AuM][I]: (member=username)
Wed Feb 27 17:52:19 2019 [Z0][AuM][D]: Message received: LOG I 39 User username is not in group cn=oneadmins,ou=groups,dc=sec,dc=t-labs,dc=tu-berlin,dc=de
Wed Feb 27 17:52:19 2019 [Z0][AuM][I]: User username is not in group cn=oneadmins,ou=groups,dc=sec,dc=t-labs,dc=tu-berlin,dc=de
Wed Feb 27 17:52:19 2019 [Z0][AuM][D]: Message received: LOG I 39 Could not authenticate user username
Wed Feb 27 17:52:19 2019 [Z0][AuM][I]: Could not authenticate user username
Wed Feb 27 17:52:19 2019 [Z0][AuM][D]: Message received: AUTHENTICATE FAILURE 39 -
Wed Feb 27 17:52:19 2019 [Z0][AuM][E]: Auth Error:
Wed Feb 27 17:52:19 2019 [Z0][ReM][D]: Req:880 UID:-1 one.user.info invoked , -1
Wed Feb 27 17:52:19 2019 [Z0][ReM][E]: Req:880 UID:- one.user.info result FAILURE [one.user.info] User couldn’t be authenticated, aborting call.
As I said the login against LDAP with the group line commented in the ldap_auth.conf is working, only when I try to allow login only to Users in a specific group.
Maybe somebody sees my error?
Greetings
Henrik
