Hello
I’m trying to run VM backups and notice a problem with live backups. My VMs has a qcow2 disk and full/incremental backup when VM is shutdown works fine. The problem is when I want to perform live backup. Then, depending on backup type occurs two problems:
incremental:
Wed Mar 13 10:22:54 2024 [Z0][VMM][I]: Error: Error executing ‘virsh --connect qemu:///system backup-begin --reuse-external --backupxml /var/lib/one//datastores/167/814/tmp/backup.xml --checkpointxml /var/lib/one//datastores/167/814/tmp/checkpoint.xml 48b71aba-6b4c-45f4-ba1f-443361995077’:
Wed Mar 13 10:22:54 2024 [Z0][VMM][I]: error: Operation not supported: creating checkpoint for incremental backup is not supported yet
full:
Wed Mar 13 10:29:54 2024 [Z0][VMM][I]: Error: Error executing ‘virsh --connect qemu:///system snapshot-create-as --name one-814-backup --disk-only --atomic --diskspec vda,file=/var/lib/one//datastores/167/814/tmp/overlay_0.qcow2 48b71aba-6b4c-45f4-ba1f-443361995077’:
Wed Mar 13 10:29:54 2024 [Z0][VMM][I]: error: Operation not supported: cannot perform block operations while checkpoint exists
Wed Mar 13 10:29:54 2024 [Z0][VMM][I]: Error preparing disk files: Error executing ‘virsh --connect qemu:///system snapshot-create-as --name one-814-backup --disk-only --atomic --diskspec vda,file=/var/lib/one//datastores/167/814/tmp/overlay_0.qcow2 48b71aba-6b4c-45f4-ba1f-443361995077’:
Wed Mar 13 10:29:55 2024 [Z0][VMM][I]: error: Operation not supported: cannot perform block
Debian 11.8
qemu 5.2.0
libvirtd 8.0.0
OpenNebula 6.8.0 CE
