Hello
I have a custom storage driver, and premigrate script not executed.
oned.conf:
TM_MAD_CONF = [
NAME = "iscsi", LN_TARGET = "NONE", CLONE_TARGET = "SELF", SHARED = "YES",
DRIVER = "raw", ALLOW_ORPHANS="YES", TM_MAD_SYSTEM = "ssh",
LN_TARGET_SSH = "SYSTEM", CLONE_TARGET_SSH = "SYSTEM", DISK_TYPE_SSH = "FILE"
onedatastore show 114
DATASTORE 114 INFORMATION
USER : oneadmin
GROUP : oneadmin
CLUSTERS : 100
TYPE : IMAGE
DS_MAD : iscsi
TM_MAD : iscsi
BASE PATH : /var/lib/one/datastores/114
DISK_TYPE : BLOCK
STATE : READY
DATASTORE CAPACITY
TOTAL: : 8T
FREE: : 8T
USED: : 287M
LIMIT: : -
OWNER : um-
GROUP : u--
OTHER : ---
DATASTORE TEMPLATE
ALLOW_ORPHANS="YES"
BASE_IQN="iqn.2012-02.org.opennebula"
BRIDGE_LIST="storage-iscsi"
CLONE_TARGET="SELF"
DATASET_NAME="space/opennebula"
DATASTORE_CAPACITY_CHECK="yes"
DISK_TYPE="BLOCK"
DRIVER="raw"
DS_MAD="iscsi"
HOST="storage-iscsi"
RESTRICTED_DIRS="/"
SAFE_DIRS="/var/tmp"
TM_MAD="iscsi"
TYPE="IMAGE_DS"
VBD_TYPE="zfs-ctl"
ZFS_BLOCK_SIZE="64k"
Log:
Tue Sep 25 09:22:18 2018 [Z0][VMM][D]: Message received: LOG I 35 Successfully execute transfer manager driver operation: tm_premigrate.
Tue Sep 25 09:22:18 2018 [Z0][VMM][D]: Message received: LOG I 35 ExitCode: 0
Tue Sep 25 09:22:18 2018 [Z0][VMM][D]: Message received: LOG I 35 Successfully execute network driver operation: pre.
Tue Sep 25 09:22:18 2018 [Z0][VMM][D]: Message received: LOG I 35 Command execution fail: cat << EOT | /var/tmp/one/vmm/kvm/migrate 'one-35' 'node2' 'node1' 35 node1
Tue Sep 25 09:22:19 2018 [Z0][VMM][D]: Message received: LOG E 35 migrate: Command "virsh --connect qemu:///system migrate --live one-35 qemu+ssh://node2/system" failed: error: Cannot access storage file '/var/lib/one/datastores/0/35/disk.1'
I’m using:
OpenNebula 5.6
Hosting server OS: Centos 7.5
Guest OS: Debian
How to solve a problem?
