**SOLVED** Live-migration problem after update to 5.2.1
hello! We recently updated OpenNebula from 4.12 to 5.2.1 and now we have problem with live migration (migration works fine) on KVM hosts.
For shared system datastore we use ceph-fs.
When I create VM I can acces following directories and files:
ls -la /var/lib/one//datastores/0/133562/
total 366
drwxrwxr-x 1 oneadmin oneadmin       374121 Feb  6 07:29 .
drwxr-x--- 1 oneadmin oneadmin 472929437079 Feb  6 07:45 ..
-rw-rw-r-- 1 oneadmin oneadmin         1385 Feb  6 07:28 deployment.20
-rw-r--r-- 1 oneadmin oneadmin       372736 Feb  6 07:29 disk.1
When I’m trying live-migration I have an error:
Mon Feb 6 07:09:44 2017 [Z0][VMM][I]: Command execution fail: cat << EOT | /var/tmp/one/vmm/kvm/migrate ‘one-133562’ ‘host05’ ‘host04’ 133562 host04
Mon Feb 6 07:09:44 2017 [Z0][VMM][E]: migrate: Command “virsh --connect qemu:///system migrate --live one-133562 qemu+ssh://host05/system” failed: error: Cannot access storage file ‘/var/lib/one//datastores/0/133562/disk.1’ (as uid:1002, gid:1002): No such file or directory
Mon Feb 6 07:09:44 2017 [Z0][VMM][E]: Could not migrate one-133562 to host
And after this error following files are missing:
ls: cannot access /var/lib/one//datastores/0/133562/: No such file or directory
i solved my problem.
I commented line 63 in /var/lib/one/remotes/tm/ceph/premigrate
63 #ssh_exec_and_log "$DST_HOST" "rm -rf '$DST_PATH'" \
$DST_PATH and $SRC_PATH is the same folder that contains context image on shared DS
So, when premigrate script remove $DST_PATH it remove $SRC_PATH
There is a solution
Thanks for reporting this issue (and for the patch!) we’ll review it and apply it shortly
We are also having this issue. Is there any guess on when the fixes will be merged?
According to Bug #4969: Ceph driver for system datastore ignores SHARED=YES - OpenNebula - OpenNebula Development pages it is queued for 5.4. But if there is another maintenance release of 5.2 I believe it will be merged there too.
Kind Regards,
Thanks, we patched the 3 files as described above and live-migrate started working again after opennebula restart
