Lock and rights do not affect on scheduled actions. security bug
Even if vm is locked, or owner currently has no rights to manage/admin or even use(by lock) the VM, user can schedule action, e.g. resume, and turn his vm on.
Steps:
  • Lock VM
  • login as user
  • schedule action, like resume
  • wait
  • vm is going to be resumed
    Expected: nothing should happen or/and action should have message, like cannot resume vm, because it’s locked/user has no rights [manage]
Hello @slnt_opp
Could you please open an issue in our GitHub with the detailed information?
Thanks!
Best,
Álex
Hello @slnt_opp,
which opennebula version do you use? (On command line you can check it with ‘oned --version’)
I just tested it with 5.10.0 and 5.10.4 and it works correctly, the schedule action fails.
We’re using 5.8.5. Unfortunately i can’t update to 5.10 now
Done
