LVM with existing VG possible?
Is there any way to use existing LVM VG with LVM driver?
Ive got only disk host so i cant create another VGs
regards
It is depending on what driver you are plannig to use.
The block LVM addon-lvm has configuration file where you can set the VG name. In the mainstream fs_lvm the VG_NAME is hard-coded. You can change the later driver to match your needs or create feature request in the dev portal.
Kind Regards,
