Hi all,
When I init LXD VM, I have problem: error while loading shared libraries: libdqlite.so.0: cannot open shared object file: No such file or directory
I am using: Opennebula 5.8.1
LXD node version: ubuntu 18.10
Thanks.
Hi all,
Thanks.
That seems to be a direct dependency of lxd missing on your setup. If you are using 1810, I imagine you are using lxd via snapd, please make sure to be using the LTS snap package version of lxd,
snap install lxd --channel=3.0/stable
Hi dann1,
I check with your command and this is resulf:
snap "lxd" is already installed, see 'snap help refresh'
root:~# snap list
Name Version Rev Tracking Publisher Notes
core 16-2.38.1 6818 stable canonical✓ core
lxd 3.12 10601 stable/… canonical✓ -
Thanks
Try swapping to the stable channel
snap refresh hello --channel=3.0/stable
or if that fails,
snap remove lxd
This is my result:
root:~# snap refresh hello --channel=3.0/stable
snap "hello" is not installed
root:~# snap remove lxd
lxd removed
root:~# snap install lxd --channel=3.0/stable
lxd (3.0/stable) 3.0.3 from Canonical✓ installed
root:~# /snap/lxd/current/bin/lxd forkstart one-29 /var/snap/lxd/common/lxd/containers /var/snap/lxd/common/lxd/logs/one-29/lxc.conf
/snap/lxd/current/bin/lxd: error while loading shared libraries: libdqlite.so.0: cannot open shared object file: No such file or directory
root:~# snap list
lxd 3.0.3 9663 3.0 canonical✓ -
Thanks
No idea, but that is a LXD specific issue, the missing library should be provided by the snap package itself.
I reinstall node OS with ubuntu 18.04 and everything fine
Thank.
