The eth0@number isn’t a problem, context was patched for that when LXD support was implemented.
I’m not able to reproduce the issue. I instantiated the VM template generated by root@ubuntu1804-lxd-marketplace-abb11-0:~# onemarketapp export 47 'centos7' -d 1.
Then added 2 NICs
root@ubuntu1804-lxd-marketplace-abb11-0:~# onevm show 49
VIRTUAL MACHINE 49 INFORMATION
USER : oneadmin
GROUP : oneadmin
STATE : ACTIVE
LCM_STATE : RUNNING
LOCK : None
RESCHED : No
HOST : ubuntu1804-lxd-marketplace-abb11-0.test
CLUSTER ID : 0
CLUSTER : default
START TIME : 07/11 19:43:51
END TIME : -
DEPLOY ID : one-49
VIRTUAL MACHINE MONITORING
CPU : 0.0
MEMORY : 0K
NETTX : 2K
NETRX : 4K
OWNER : um-
GROUP : ---
OTHER : ---
VM DISKS
ID DATASTORE TARGET IMAGE SIZE TYPE SAVE
0 default hda centos7 -/1024M file NO
1 - hdb CONTEXT -/- - -
VM NICS
ID NETWORK BRIDGE IP MAC PCI_ID
0 public br0 192.168.150.100 02:00:c0:a8:96:64
1 public br0 192.168.150.101 02:00:c0:a8:96:65
SECURITY
NIC_ID NETWORK SECURITY_GROUPS
0 public 0
1 public 0
SECURITY GROUP TYPE PROTOCOL NETWORK RANGE
ID NAME VNET START SIZE
0 default OUTBOUND ALL
0 default INBOUND ALL
VIRTUAL MACHINE HISTORY
SEQ UID REQ HOST ACTION DS START TIME PROLOG
0 - - ubuntu1804-l none 0 07/11 19:43:52 0d 00h02m 0h00m02s
USER TEMPLATE
HYPERVISOR="lxd"
LXD_SECURITY_PRIVILEGED="true"
VIRTUAL MACHINE TEMPLATE
AUTOMATIC_DS_REQUIREMENTS="(\"CLUSTERS/ID\" @> 0)"
AUTOMATIC_NIC_REQUIREMENTS="(\"CLUSTERS/ID\" @> 0)"
AUTOMATIC_REQUIREMENTS="(CLUSTER_ID = 0) & !(PUBLIC_CLOUD = YES)"
CONTEXT=[
DISK_ID="1",
ETH0_CONTEXT_FORCE_IPV4="",
ETH0_DNS="10.0.0.2",
ETH0_EXTERNAL="",
ETH0_GATEWAY="192.168.150.1",
ETH0_GATEWAY6="",
ETH0_IP="192.168.150.100",
ETH0_IP6="",
ETH0_IP6_PREFIX_LENGTH="",
ETH0_IP6_ULA="",
ETH0_MAC="02:00:c0:a8:96:64",
ETH0_MASK="",
ETH0_MTU="",
ETH0_NETWORK="",
ETH0_SEARCH_DOMAIN="",
ETH0_VLAN_ID="",
ETH0_VROUTER_IP="",
ETH0_VROUTER_IP6="",
ETH0_VROUTER_MANAGEMENT="",
ETH1_CONTEXT_FORCE_IPV4="",
ETH1_DNS="10.0.0.2",
ETH1_EXTERNAL="",
ETH1_GATEWAY="192.168.150.1",
ETH1_GATEWAY6="",
ETH1_IP="192.168.150.101",
ETH1_IP6="",
ETH1_IP6_PREFIX_LENGTH="",
ETH1_IP6_ULA="",
ETH1_MAC="02:00:c0:a8:96:65",
ETH1_MASK="",
ETH1_MTU="",
ETH1_NETWORK="",
ETH1_SEARCH_DOMAIN="",
ETH1_VLAN_ID="",
ETH1_VROUTER_IP="",
ETH1_VROUTER_IP6="",
ETH1_VROUTER_MANAGEMENT="",
NETWORK="YES",
SET_HOSTNAME="centos7-49",
SSH_PUBLIC_KEY="ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQCYz+lkZoNyspRhrtXDKFN3cIEwN3w08mz0YGKpVDIiV0+/vgG8dAUQ70Irs3m83W9BHN+vNjKPgKcF+X+sSfxniOtavahxGCRjAhhs1IVm196C5ODbSgXVUWULdtmMHelXbLBJ8X340h/UO+eQ6eRLaRfslXUsgRqremVcvCCPz4LIuRiliGWiELAmqYcY+1zJLeg3QV2Pgn5vschM9e/A4AseKO+HnbGB/I5tnoeZT/Gc3FGfUZLNFVB2XsVGAEEzkqO8VI2msB7MCAZBHffIK6WfLIYgGP6Ha2JT1NWJU7Ncj9Xuql0ElF01VwWMDWzqc0DOiVSsTL89ugJKU6+h one",
TARGET="hdb" ]
CPU="1"
GRAPHICS=[
LISTEN="0.0.0.0",
PORT="5949",
TYPE="vnc" ]
MEMORY="768"
TEMPLATE_ID="43"
TM_MAD_SYSTEM="qcow2"
VMID="49"
Network is fine
root@ubuntu1804-lxd-marketplace-abb11-0:~# lxc exec one-49 -- ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
113: eth0@if114: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 02:00:c0:a8:96:64 brd ff:ff:ff:ff:ff:ff link-netnsid 0
inet 192.168.150.100/24 brd 192.168.150.255 scope global eth0
inet6 fe80::c0ff:fea8:9664/64 scope link
115: eth1@if116: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 02:00:c0:a8:96:65 brd ff:ff:ff:ff:ff:ff link-netnsid 0
inet 192.168.150.101/24 brd 192.168.150.255 scope global eth1
inet6 fe80::c0ff:fea8:9665/64 scope link
