DaD
(Daniel Dehennin)
March 18, 2015, 7:58am
1
Using ONE 4.10 with shared datastores.
I have two VMs in SHUTDOWN on a host named nebula1.
This host is down and I want the VMs to boot on another host.
I tried ./remotes/hooks/ft/host_error.rb 0 --recreate but it does not seems to work for VMs in SHUTDOWN.
Any hints?
Regards.
ruben
(Rubén S. Montero)
March 18, 2015, 4:58pm
2
You can make those VMs progress with onevm recover actions, to flag the
shutdown operation either to fail or success. This will transition the VM
to the final state, DONE, FAILED etc…
Cheers
DaD
(Daniel Dehennin)
March 18, 2015, 5:18pm
3
“Ruben S. Montero” forum@opennebula.org writes:
I tried but I got a “Wrong state to perform action” Error :-/
Tomorrow I’ll attach logs for this.
Regards.
Daniel Dehennin
ruben
(Rubén S. Montero)
March 18, 2015, 5:28pm
4
I’d also be interested in the VM states, onevm show -x would help
DaD
(Daniel Dehennin)
March 19, 2015, 7:50am
5
Here are the logs for VM 724
Thu Mar 19 08:36:30 2015 [Z0][ReM][D]: Req:6672 UID:0 VirtualMachineRecover invoked , 724, true
Thu Mar 19 08:36:30 2015 [Z0][ReM][E]: Req:6672 UID:0 VirtualMachineRecover result FAILURE [VirtualMachineRecover] Wrong state to perform action
Here is the state of the VM 724
<VM>
<ID>724</ID>
<LAST_POLL>1426670854</LAST_POLL>
<STATE>8</STATE>
<LCM_STATE>0</LCM_STATE>
<RESCHED>0</RESCHED>
<STIME>1426589313</STIME>
<ETIME>0</ETIME>
<DEPLOY_ID>one-724</DEPLOY_ID>
<MEMORY>0</MEMORY>
<CPU>0</CPU>
<NET_TX>789521</NET_TX>
<NET_RX>14216909</NET_RX>
</VM>
The other VM
<VM>
<ID>52</ID>
<LAST_POLL>0</LAST_POLL>
<STATE>8</STATE>
<STIME>1421762562</STIME>
<ETIME>0</ETIME>
<DEPLOY_ID>one-52</DEPLOY_ID>
<MEMORY>0</MEMORY>
<CPU>0</CPU>
<NET_TX>257270817</NET_TX>
<NET_RX>10132972350</NET_RX>
</VM>
The host is now up, so my problem will be solved soon, but if you want
more informations I will not touch the VM 724.
Regards.
Daniel Dehennin
ruben
(Rubén S. Montero)
March 24, 2015, 4:37pm
7
Hi Daniel,
I missed you last post :S Anyway, the VMs are in poweroff, they can only be migrated if they get back to running.
We have this issue to address this:
http://dev.opennebula.org/issues/3654
Cheers
