I am migrating KVM VMs from Archipel orchestrator, which includes importing mutiple VM disk images into Opennebula 5.2 datastore.
I am using CLI oneimage create command.
When I execute command it returns right away, but when I do it mutiple times for mutiple images I notice that images are getting queued - is it intentional or there is some configuration piece missing in my setup?
(4 Opennebula nodes, NFS image store)
Opennebula 5.2
Try to import multiple qcow2 images via “oneimage create”. Say
oneimage create --name "os-1" --type OS --description "os1" --path=/var/tmp/vms2/vm/drives/xxx/os1.qcow2 --driver qcow2 -d imgfsds oneimage create --name "bkp1" --type DATABLOCK --description "bkp1" --path=/var/tmp/vms2/vm/drives/xxx/bkp1.qcow2 -d imgfsds --driver qcow2
Watch staging DIR for file import progress, you will see that until 1st image file finished copying, next image file will not start.
Image files should be imported in parallel independently from each other, in as many threads as many oneimage create processes are executed.
