I have some /h trying to set network up but i’ve fail!
i just want to setup the network to
- have access on internet directly from guest vm.
- having a static ip.
i’ve setup this way on virtualbox, And is with One NAT and static ip.
but i don’t know how to make this works with OpenNebula or to create a NAT network.
so i’m using virbr0 which is created by default!
you can watch this vid about how i’ve configure network https://vid.me/Xq3X (u can make it HD)
and you can see that when i change interface eth0 from static to dhcp it starts to ping google so i have internet.
But as normal when i create a vm i doesn’t have internet
can someone help me?!
Thanks…
My Host OS : Ubuntu 14.04
OpenNebula Version 5.2
