[SOLVED] Route public network to VM
Hi!
I’m trying to get public network on my VM, so public IP’s which it may use.
I can assign an IP and all, that’s no issue. However the problem is the actual network.
My public IP on my host is on em1, but when I use that interface it says it is not able to use it.
So I think I need a bridge, but I’ve never done this before. I can’t find the bridge that comes when you install Opennebula anywhere in a config file so I can’t copy it as well.
Is someone able to help me out how I get public internet on my VM?
Thanks in advance!
I apologize for my English, it is not my mother language!
Fixed it. Just make a bridge of your public network, and create the virtual network.
Hi Florius, could you share your virtual network configuration? I’m currently in the same problem.
Thanks
