I have a somewhat strange problem importing Wilds from my vCenter.
When I import a VM from vCenter 7 into my OpenNebula 6, it works fine. But now when I try to import a second VM which is connected to the same network as the previously imported VM, I get the message: “Cannot get IP/MAC lease from virtual network”.
When importing the 1st VM, OpenNebula creates a virtual network. In the addresses I see the IP and MAC of the failed VM, but the VM itself is missing.
For testing, I downloaded the OVA v6 and imported it in to my vmware environment. When importing the second VM I get exactly the same error message as with the installed version.
I have exactly this same issue. New CE 6.0.2 install, so it’s all fresh, and I tried to add my wilds.
The first few imports created the virtual networks and I got a few wild VMs on each of those networks to import. When I try and do the rest I get “Cannot get IP/MAC lease from virtual network”.
Damm even I am having a similar kind of issue, I have searched all over the internet and even have posted on number of threads on different forum, no solution seems to work. I am really frustrated, can anyone of you here help me resolve this issue, I am very much tired now.
Can you share the output of onevnet show -x <VNET_ID>. If you have VMs succesfully attached to that virtual net, can you share the output of onevm shox -x <VM_ID>.
Hello everybody. Thank you for reporting this bug.
We have identified a bug that was related to IPv6 when it came from vCenter in a different order.
Before it did not happen because new ARs were always created for each IP but in 6.0 we have made several improvements to avoid repeated data, in the next release it will be fixed.
Hi @cherrera , i do the modification on the file [src/vmm_mad/remotes/lib/vcenter_driver/vm_template.rb] but the issue is still present, are you sure that you need to made just this modification ?
all of the wild machine with ipv6 cannot be imported on opennebula
