Network Problems VM not reaching local network (openvswitch)
Hi All,
I have a debian Host, deploying VM’s is working. The bridge ist up an running:
root@ammersee3:~# ovs-vsctl show
ada97ae6-d45d-4023-83a2-730ce386d459
Bridge "br0"
Port "eth0"
Interface "eth0"
Port "br0"
Interface "br0"
type: internal
Port "vnet1"
Interface "vnet1"
Port "vnet0"
Interface "vnet0"
ovs_version: “2.3.0”
On the VM I have an IP-Adresse (eth0: 192.168.22.180)and if I ping the second VM I get response. But as I ping a host on the local net (e.g the node, or the router) I get no response. From a host to the VM it doesn’t work also.
source /etc/network/interfaces.d/*
The loopback network interface
auto lo
iface lo inet loopback
The primary network interface
allow-hotplug eth0
auto eth0
iface eth0 inet static
auto br0
iface br0 inet static
address 192.168.22.111
network 192.168.22.0
netmask 255.255.255.0
broadcast 192.168.22.255
gateway 192.168.22.1
bridge_ports eth0
bridge_fd 9
bridge_hello 2
bridge_maxage 12
bridge_stp off
So whats wrong.
Thx
Thomas
Sorry for the late reply. Thinks work a bit different when using openvswitch compared to legacy bridging.
On openvswitch you should create a “access port” for your host, i.e.:
ovs-vsctl add-port br0 br0-host – set interface br-host type=internal
In your network intefaces file you would have the following:
auto lo
auto eth0
iface eth0 inet manual
pre-up ip link set $IFACE up
post-down ip link set $IFACE down
auto br0-host
iface br0-host inet static
P.s. If you want to configure spanning tree stuff … you should do so with openvswitch commands on the openvswitch bridge. Specifying this in network interfaces file won’t work.
If you want to use vlans in some point in time on your bridge you could do the following to make an “access port” available to the host (for a specific vlan). For example vlan 101 (tagged on physical switch port corresponding with eth0 in host):
put (tagged) vlan on bridge
ovs-vsctl set port br0 trunks=101
create interface “vlan101” for host in vlan 101
ovs-vsctl add-port br0 vlan101 tag=101 – set interface vlan101 type=internal
