Found solution in doc. [SOLVED]
Hi @UAnton,
Could you please add the URL that you usage to fix it ?
Thanks in advance!
Cheers
-Carlos
Hi! Use ACL! Delete All in Networks and add only you need network ID.
От 25 октября 2016 г. в 17:45:06, Carlos Cesario (
opennebula@discoursemail.com) написал:
ccesario https://forum.opennebula.io/users/ccesario Carlos Cesario
October 25
Hi @UAnton https://forum.opennebula.io/users/uanton,
[image:
Thanks in advance!
Cheers
-Carlos
