Hi, my Name ist Heinz and i´m really newbie.
First of all i try to set up a Open Nebula CLuster with Ceph as datastore.
Open Nebula Cluster
1 Frontend called Nebula01 (HP DL 360 G6)
3 Nodes called Cnode01, Cnode02, Cnode03 (2 x HP DL 360 G8 , 1 x DL 360 G6)
Ceph Cluster
1 x Admin, Deploy Node called Cephmon01 (HP DL 360 G6)
3 x Mon Nodes called Cephnode01, Cephnode02, Cephnode03 (HP DL 360 G6)
Open Nebula configured Basic based on the Quick Start Dokumentation
https://docs.opennebula.org/5.4/deployment/open_cloud_storage_setup/ceph_ds.html
oneadmin@Nebula01:~$ tree -ps /var/lib/one/datastores/
├── [drwxr-xr-x 4096] 0
├── [drwxr-xr-x 4096] 1
│ ├── [-rw-r–r-- 248529635] 08366c48e2690f2e2610598ebed5b3d6
│ └── [-rw-r–r-- 24933376] afcf5fe247928aa98d2261171d0fe1c2
└── [drwxr-xr-x 4096] 2
3 directories, 2 files
sgadmin@Cnode01:/$ lsmod | grep kvm
kvm_amd 65536 0
kvm 544768 1 kvm_amd
irqbypass 16384 1 kvm
oneadmin@Nebula01:~$ onedatastore show cephds
DATASTORE 101 INFORMATION
USER : oneadmin
GROUP : oneadmin
CLUSTERS : 0
TYPE : IMAGE
DS_MAD : ceph
TM_MAD : ceph
BASE PATH : /var/lib/one//datastores/101
DISK_TYPE : RBD
STATE : READY
DATASTORE CAPACITY
TOTAL: : 0M
FREE: : 0M
USED: : 0M
LIMIT: : -
OWNER : uma
GROUP : u–
OTHER : —
DATASTORE TEMPLATE
ALLOW_ORPHANS="YES"
BRIDGE_LIST="cnode01"
CEPH_HOST="cephnode01:6789 cephnode02:6789 cephnode03:6789"
CEPH_SECRET="e11a118b-851c-4b1e-9563-abbf526af28d"
CEPH_USER="libvirt"
DISK_TYPE="RBD"
DS_MIGRATE="NO"
POOL_NAME="one"
RBD_FORMAT=“2"
RESTRICTED_DIRS=”/“
SAFE_DIRS=”/var/tmp"
SHARED="YES"
TM_MAD="ceph"
TYPE=“SYSTEM_DS”
IMAGES
oneadmin@Nebula01:~$ cat ds
cat: ds: No such file or directory
oneadmin@Nebula01:~$ cat ds.conf
cat: ds.conf: No such file or directory
oneadmin@Nebula01:~$ onedatastore show ceph_system
DATASTORE 100 INFORMATION
USER : oneadmin
GROUP : oneadmin
CLUSTERS : 0
TYPE : SYSTEM
DS_MAD : -
TM_MAD : ceph
BASE PATH : /var/lib/one//datastores/100
DISK_TYPE : RBD
STATE : READY
DATASTORE CAPACITY
TOTAL: : 0M
FREE: : 0M
USED: : 0M
LIMIT: : -
OWNER : um-
GROUP : u–
OTHER : —
DATASTORE TEMPLATE
ALLOW_ORPHANS="YES"
CEPH_USER="libvirt"
DISK_TYPE="RBD"
DS_MIGRATE="NO"
POOL_NAME="one"
RBD_FORMAT=“2"
RESTRICTED_DIRS=”/“
SHARED="YES"
TM_MAD="ceph"
TYPE=“SYSTEM_DS”
Ceph Cluster configured Basic based on Ceph Quickstart Dokumentation
health HEALTH_OK
monmap e3: 3 mons at {cephnode01=10.8.0.15:6789/0,cephnode02=10.8.0.16:6789/0,cephnode03=10.8.0.17:6789/0}
election epoch 12, quorum 0,1,2 cephnode01,cephnode02,cephnode03
osdmap e162: 18 osds: 18 up, 18 in
flags sortbitwise,require_jewel_osds
pgmap v4296: 232 pgs, 7 pools, 1588 bytes data, 171 objects
746 MB used, 9477 GB / 9477 GB avail
232 active+clean
ceph osd lspools
0 rbd,1 .rgw.root,2 default.rgw.control,3 default.rgw.data.root,4 default.rgw.gc,5 default.rgw.log,6 one,
And now my problems:
i tried to verifiy my Opennebula Installation with 3.4.1 KVM Based Cloud Verification
i imported the TTYLinux Template on the defoult configuerd datastore (not Ceph)…but don´t wont start with error:
- deploy_action, error getting driver kv
- New LCM state is BOOT_FAILURE
2nd. Problem:
my Ceph Datastore isn´t correct configured, it shows 0 Space
It´s a desaster for a newbie like me.
Please help…Team Viewer Session it´s also a solution.
Regards Heinz
