Hello, I’m new to OpenNebula and have been trying to setup OpenNebula + Guacamole for a task. I’ve been following the blog post on how to create a windows image. How to Build an Image for Windows Virtual Machines – OpenNebula Customer Portal
OpenNebula 6.10.0.1
OS VM: Debian 12
ISO used for the VM is Windows 10 Eval
Follow the guide in creating Windows Image.
Expected for the drivers mentioned in the guide to be displayed.
Additional screenshot of setup:
Thank you in advance.
try manually pointing to the exact folder of the drivers by pressing “Browse”
I have tried to do that but it seems like the disk is not showing up or being attached to the instance. Here’s my storage setup, VM Template and also logs.
Fri Mar 7 20:35:20 2025 [Z0][VM][I]: New state is ACTIVE
Fri Mar 7 20:35:20 2025 [Z0][VM][I]: New LCM state is PROLOG
Fri Mar 7 20:35:27 2025 [Z0][VM][I]: New LCM state is BOOT
Fri Mar 7 20:35:27 2025 [Z0][VMM][I]: Generating deployment file: /var/lib/one/vms/0/deployment.0
Fri Mar 7 20:35:29 2025 [Z0][VMM][I]: Successfully execute transfer manager driver operation: tm_context.
Fri Mar 7 20:35:30 2025 [Z0][VMM][I]: ExitCode: 0
Fri Mar 7 20:35:30 2025 [Z0][VMM][I]: Successfully execute network driver operation: pre.
Fri Mar 7 20:35:30 2025 [Z0][VMM][I]: Successfully execute virtualization driver operation: /bin/mkdir -p.
Fri Mar 7 20:35:30 2025 [Z0][VMM][I]: Successfully execute virtualization driver operation: /bin/cat - >/var/lib/one//datastores/0/0/vm.xml.
Fri Mar 7 20:35:30 2025 [Z0][VMM][I]: Successfully execute virtualization driver operation: /bin/cat - >/var/lib/one//datastores/0/0/ds.xml.
Fri Mar 7 20:35:37 2025 [Z0][VMM][I]: ExitCode: 0
Fri Mar 7 20:35:37 2025 [Z0][VMM][I]: Successfully execute virtualization driver operation: deploy.
Fri Mar 7 20:35:40 2025 [Z0][VMM][I]: Ignoring deprecated --wait-interval option.
Fri Mar 7 20:35:40 2025 [Z0][VMM][I]: ExitCode: 0
Fri Mar 7 20:35:40 2025 [Z0][VMM][I]: Successfully execute network driver operation: post.
Fri Mar 7 20:35:40 2025 [Z0][VM][I]: New LCM state is RUNNING
Fri Mar 7 20:47:31 2025 [Z0][VM][I]: New LCM state is SHUTDOWN
Fri Mar 7 20:47:33 2025 [Z0][VMM][I]: ExitCode: 0
Fri Mar 7 20:47:33 2025 [Z0][VMM][I]: Successfully execute virtualization driver operation: cancel.
Fri Mar 7 20:47:36 2025 [Z0][VMM][I]: Ignoring deprecated --wait-interval option.
Fri Mar 7 20:47:36 2025 [Z0][VMM][I]: ExitCode: 0
Fri Mar 7 20:47:36 2025 [Z0][VMM][I]: Successfully execute network driver operation: clean.
Fri Mar 7 20:47:36 2025 [Z0][VM][I]: New LCM state is EPILOG
Fri Mar 7 20:47:37 2025 [Z0][VM][I]: New state is DONE
Fri Mar 7 20:47:37 2025 [Z0][VM][I]: New LCM state is LCM_INIT
VM Template:
"CONTEXT": {
"NETWORK": "YES",
"SSH_PUBLIC_KEY": "$USER[SSH_PUBLIC_KEY]"
"CPU": "2",
"DISK": [
"DEV_PREFIX": "vd",
"IMAGE": "Windows Data Block",
"IMAGE_UNAME": "oneadmin"
"IMAGE": "Windows ISO",
"IMAGE": "Virtio Windows Driver",
"IMAGE": "ONE Context Driver",
"GRAPHICS": {
"LISTEN": "0.0.0.0",
"PASSWD": "4rHRuxQZtv",
"TYPE": "VNC"
"HYPERVISOR": "kvm",
"INPUT": {
"BUS": "usb",
"TYPE": "tablet"
"MEMORY": "4096",
"MEMORY_RESIZE_MODE": "BALLOONING",
"NIC": {
"NETWORK": "vnet",
"NETWORK_UID": "0",
"NETWORK_UNAME": "oneadmin"
"OS": {
"BOOT": "disk1"
"SCHED_REQUIREMENTS": "(HYPERVISOR=kvm)",
"VCPU": "2"
Windows Data Block:
Windows ISO:
VirtIO Driver:
ONE Context:
can you try changing the bus of the virtio to “Parallel ATA (IDE)”. i have checked this now and when i choose SCSI/SATA for the bus of the virtio iso, it doesn’t show up too in my end as well
Thank you! That was the fix. After that I encountered an error saying “Windows can’t be installed on this disk”
This can easily fixed setting the disk as bootable along with the ISO. Reference: Attempting to create a windows 10 image - Community Support / Storage - OpenNebula Community Forum
Thank you, hope this helps anything else facing the same.
