ONE 7 / Linbit CE Issue
  1. Import image from marketplace to DS intel_image : eg Ubuntu 22.04
  2. Image gets downloaded to KVM - I can see it in linstor resource list. eg intel1/intel2/amd1image
  3. instantiate a VM and deploy to intel1 - no issues
  4. instantiate a VM and deploy to intel2 - BOOT_FAILURE (vmlog: Image is not in qcow2 format)
  5. viceversa - if image downloads to intel2 (1st on linstor resource list) and VM on intel2 deploys fine but not on intel1.
why is it that the VM deploys fine on a kvm and not the other. Depending where the image is downloaded from ONE marketplace and appears first on the list - see above for Image-74. Intel1 appears first on the list.
here is the log for the unsuccessful deploy:
Thu Nov 20 14:53:50 2025 [Z0][VMM][I]: ExitCode: 0
Thu Nov 20 14:53:50 2025 [Z0][VMM][I]: Successfully execute network driver operation: clean.
Thu Nov 20 14:53:50 2025 [Z0][VMM][I]: Failed to execute virtualization driver operation: deploy.
Thu Nov 20 14:53:50 2025 [Z0][VMM][E]: DEPLOY: XPath set is emptyerror: Failed to create domain from /var/lib/one//datastores/109/72/deployment.0error: internal error: process exited while connecting to monitor: 2025-11-20T12:53:49.501177Z qemu-kvm-one: -blockdev {“node-name”:“libvirt-1-format”,“read-only”:false,“discard”:“unmap”,“cache”:{“direct”:true,“no-flush”:false},“driver”:“qcow2”,“file”:“libvirt-1-storage”,“backing”:null}: Image is not in qcow2 formatCould not create domain from /var/lib/one//datastores/109/72/deployment.0ExitCode: 255
VM should deploy to hosts intel1 and intel2
resolved.
all satellite nodes need to be accessible to each other.
