TiDjY35
(TiDjY35)
1
I have this error when I want to map a usb key in my VM
my config file for update
I use
- OpenNebula 6.0.0.2 on Ubuntu 18.04
- libvirtd (libvirt) 4.0.0
I modified the files as shown here but without success
Thanks
rdiaz
(Ricardo Díaz)
2
Hi @TiDjY35,
Please make sure your raw section can be validated against the libvirt schema that you can find in /usr/share/one/schemas/libvirt/domaincommon.rng.
Cheers.
rdiaz
(Ricardo Díaz)
4
Please try with: <devices><hostdev mode='subsystem' type='usb'><source><vendor id='0x1cf1'/><product id='0x0030'/></source></hostdev></devices>
Note that in the screenshot you sent there is no space between product and id.
Hope this helps.
TiDjY35
(TiDjY35)
5
I could have damaged my eyes for a long time before seeing this. I have made a copy / paste of the return provided by the DMESG.
it works with ZeroorMore modification in /usr/share/one/schemas/libvirt/domaincommon.rng
Merci @rdiaz
