Versions of the related components and OS (frontend, hypervisors, VMs): Frontedd 7.0.2 debian 12 VM on kvm host
Steps to reproduce: tried with ip address and then with host fqdn
Current results: with ip address set in oned.conf http://ip.address.here onegate vm show comes back with correct info if I change it to fqdn http://onegate.mydomin.com I get the message “host not permitted”
I have tried internally and externally with same results.
I even tried setting :ssl_server: https://service.endpoint.fqdn:port/ in onegate-server.conf and tried througth my proxy , caddy in this case and still always “Host not permitted message”
Exected results:
I expected to result showing the VM id like when I use the ip address.
Thanks all
-vizo-
