Oneshowback columns too narrow
I have noticed that “oneshowback list” shows an output with a USER_NAME too narrow, showing only first 8 characters of the username. Is there anyway to expand this size?
Also, column GROUP_NAME only shows 8 characters, so it’s the same problem as USER_NAME column.
Thanks.
Hey @Daniel_Ruiz_Molina
You could tweak the CLI tools using the configuration in /etc/one/cli/. In your case you need to tweak /etc/one/cli/oneshowback.yaml.
Hope this helps.
Best Regards,
Hello @Daniel_Ruiz_Molina @atodorov_storpool
You can use the configuration files, but you can also use some options like --expand or --size. Check this for more information.
Best,
Álex.
oneshowback has not “–expand” or “–size” options (I’m running OpenNebula 5.10.1).
Thanks a lot!!! Now, I can get all information.
