Hello all.
I have a question regarding oneshowback. Is the output everytime calculated i say so? Or is it somewhat / somewhere cached. I’m asking because i changed a few numbers but the cost stay the same.
thanks and cheers
t.
Hello all.
thanks and cheers
t.
The reports need to be calculated, they are not refreshed every time you run oneshowback list.
See: http://docs.opennebula.org/5.0/operation/users_groups_management/showback.html#calculate-monthly-reports
Hi Carlos.
Thanks for your answer. I guess my question was not precise. Let’s say i have calculated for 09/16. After that i change the cost for cpu per hour. Are the costs recalculated if i run oneshowback for 09/16 again?
thanks and cheers
t.
Another question. Can i reset the calculated costs somewhere so i can have a fresh start?
thanks and cheers
t.
