It seems the showback calculation is inaccurate when vm is powerd off. I made a vm template with below properties:
CPU: 2
Memory: 2 GB
Disk: 12 GB (Using a 12GB disk image)
CPU Cost: 20
Memory Cost: 10
Disk: 30
Then I created a user (TestVDCUser, uid: 12) and made a vm (vm id: 12) from the mentioned template. After 1 hour I did the below commands:
[root@localhost ~]# onevm poweroff 12
[root@localhost ~]# oneshowback calculate -s $(date +“%F”)
[root@localhost ~]# oneshowback list -u 12
Showback for 11/2020
USER_NAM GROUP_NA VM_ID VM_NAME MONTH YEAR HOURS COST
TestVDCU MehdiTes 12 Mehdi-Test-Show 11 2020 1.00 419.07
Calculating the user showback by hand show the opennebula calculated COST for the user is slightly the same as manual calculation:
(1021)+(2021)+(30121) = 420
Now that the vm is powerd off, we wiaited for another 1 hour to calculate the new user showback:
TestVDCU MehdiTes 12 Mehdi-Test-Show 11 2020 2.00 837.90
Because the vm was powerd off along the next 1 hour, we expect just Disk cost will be applied in user cost. Then calculation for this time range shows:
3012(2.00-1.00) = 360
At the same time the cost increaded 418.83 (837.90-419.07) that is not what we expected (we expected 360)
