I am receiving incorrect calculations with showback.
For example, I have a template with the following settings:
.000001/mb ram/hr
.005/cpu/hr
.0000137/gb disk/hr
That template has:
3072MB of RAM
2 vCPU @ 2pCPU
1x 10GB disk
It ran for 721 hours and opennebula calculated cost to be $414.02. It should be about $9.38
[root@dc1srvopennebula01 ~]# rpm -qa | grep nebula
opennebula-flow-5.4.1-1.x86_64
opennebula-ruby-5.4.1-1.x86_64
opennebula-gate-5.4.1-1.x86_64
opennebula-sunstone-5.4.1-1.x86_64
opennebula-node-kvm-5.4.1-1.x86_64
opennebula-common-5.4.1-1.x86_64
opennebula-5.4.1-1.x86_64
opennebula-server-5.4.1-1.x86_64
[root@dc1srvopennebula01 ~]# uname -a
Linux dc1srvopennebula01.laureateinstitute.org 3.10.0-693.5.2.el7.x86_64 #1 SMP Fri Oct 20 20:32:50 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
[root@dc1srvopennebula01 ~]# cat /etc/centos-release
CentOS Linux release 7.4.1708 (Core)
AUTOMATIC_DS_REQUIREMENTS = "“CLUSTERS/ID” @> 0"
AUTOMATIC_REQUIREMENTS = "(CLUSTER_ID = 0) & !(PUBLIC_CLOUD = YES)"
CLONING_TEMPLATE_ID = "47"
CONTEXT = [
CONTEXT = “true”,
DISK_ID = “1”,
ETH0_CONTEXT_FORCE_IPV4 = “”,
ETH0_DNS = “8.8.8.8”,
ETH0_GATEWAY = “10.124.250.1”,
ETH0_GATEWAY6 = “”,
ETH0_IP = “10.124.250.32”,
ETH0_IP6 = “”,
ETH0_IP6_PREFIX_LENGTH = “”,
ETH0_IP6_ULA = “”,
ETH0_MAC = “02:00:0a:7c:fa:20”,
ETH0_MASK = “”,
ETH0_MTU = “”,
ETH0_NETWORK = “”,
ETH0_SEARCH_DOMAIN = “”,
ETH0_VLAN_ID = “2500”,
ETH0_VROUTER_IP = “”,
ETH0_VROUTER_IP6 = “”,
ETH0_VROUTER_MANAGEMENT = “”,
ETH1_CONTEXT_FORCE_IPV4 = “”,
ETH1_DNS = “”,
ETH1_GATEWAY = “”,
ETH1_GATEWAY6 = “”,
ETH1_IP = “10.124.17.120”,
ETH1_IP6 = “”,
ETH1_IP6_PREFIX_LENGTH = “”,
ETH1_IP6_ULA = “”,
ETH1_MAC = “02:00:0a:7c:11:78”,
ETH1_MASK = “”,
ETH1_MTU = “”,
ETH1_NETWORK = “”,
ETH1_SEARCH_DOMAIN = “”,
ETH1_VLAN_ID = “17”,
ETH1_VROUTER_IP = “”,
ETH1_VROUTER_IP6 = “”,
ETH1_VROUTER_MANAGEMENT = “”,
IMAGE = “Context”,
NETWORK = “YES”,
SET_HOSTNAME = “admin”,
SSH_PUBLIC_KEY = “$USER[SSH_PUBLIC_KEY]”,
START_SCRIPT_BASE64 = “eXVtIGluc3RhbGwgLXkgaHRvcCB2aW0=”,
TARGET = “hda” ]
CPU = "2"
CPU_COST = "0.005"
DISK = [
ALLOW_ORPHANS = “YES”,
CEPH_HOST = “10.124.103.60 10.124.103.61 10.124.103.62”,
CEPH_SECRET = “cee873d6-f586-4732-beb6-ae624ad34864”,
CEPH_USER = “libvirt”,
CLONE = “NO”,
CLONE_TARGET = “SELF”,
CLUSTER_ID = “0”,
DATASTORE = “ceph_one_image”,
DATASTORE_ID = “107”,
DEV_PREFIX = “vd”,
DISK_ID = “0”,
DISK_SNAPSHOT_TOTAL_SIZE = “0”,
DISK_TYPE = “RBD”,
DRIVER = “raw”,
IMAGE = “admin-disk-0”,
IMAGE_ID = “282”,
IMAGE_STATE = “10”,
LN_TARGET = “NONE”,
ORDER = “1”,
ORIGINAL_SIZE = “40960”,
PERSISTENT = “YES”,
POOL_NAME = “one”,
READONLY = “NO”,
SAVE = “YES”,
SIZE = “40960”,
SOURCE = “one/one-282”,
TARGET = “vda”,
TM_MAD = “ceph”,
TYPE = “RBD” ]
DISK_COST = "1.37e-05"
FEATURES = [
ACPI = “yes”,
GUEST_AGENT = “yes” ]
GRAPHICS = [
LISTEN = “0.0.0.0”,
PORT = “6031”,
TYPE = “VNC” ]
MEMORY = "3072"
MEMORY_COST = "1e-06"
NIC = [
AR_ID = “0”,
BRIDGE = “br0”,
CLUSTER_ID = “0”,
DNS = “8.8.8.8”,
FILTER_IP_SPOOFING = “YES”,
FILTER_MAC_SPOOFING = “YES”,
NETWORK = “dev-ceph_public”,
NETWORK_ID = “2”,
NIC_ID = “0”,
SECURITY_GROUPS = “0”,
TARGET = “one-131-0”,
VLAN_ID = “2500”,
VN_MAD = “ovswitch” ]
NIC = [
AR_ID = “0”,
BRIDGE = “br0”,
CLUSTER_ID = “0”,
NETWORK = “Prod-IT-Desktop”,
NETWORK_ID = “4”,
NETWORK_UNAME = “oneadmin”,
NIC_ID = “1”,
TARGET = “one-131-1”,
VLAN_ID = “17”,
OS = [
BOOT = “disk0” ]
SECURITY_GROUP_RULE = [
PROTOCOL = “ALL”,
RULE_TYPE = “OUTBOUND”,
SECURITY_GROUP_ID = “0”,
SECURITY_GROUP_NAME = “default” ]
PROTOCOL = “ALL”,
RULE_TYPE = “INBOUND”,
TEMPLATE_ID = "109"
VCPU = "2"
VMID = “131”
create template with costs assigned above
414.02
9.38
