Hi all,
I’m trying to setup an Marketplace with the S3 driver on a Ceph RADOS Gateway:
The Ceph stuff works. I’ve checked it with the s3cmd and was able to create the bucket.
On the OpenNebula side I dicovered two problems.
First the simple one a UI thing:
The Endpoint isn’t displayed in the ‘Wizard’ Sunstone UI while editing. The ‘Advaned’ Tab shows all data correctly.
The second one is the harder one.
I’m receiving an error in the in the oned logs:
Fri Jun 3 11:29:11 2016 [Z0][MKP][I]: Command execution fail: /var/lib/one/remotes/market/s3/monitor …
Fri Jun 3 11:29:11 2016 [Z0][MKP][I]: /var/lib/one/remotes/market/s3/S3.rb:26:in initialize': uninitialized constant S3::Aws (NameError) Fri Jun 3 11:29:11 2016 [Z0][MKP][I]: from /var/lib/one/remotes/market/s3/monitor:76:innew’
Fri Jun 3 11:29:11 2016 [Z0][MKP][I]: from /var/lib/one/remotes/market/s3/monitor:76:in `'
Fri Jun 3 11:29:11 2016 [Z0][MKP][I]: ExitCode: 1
Fri Jun 3 11:29:11 2016 [Z0][MKP][E]: Error monitoring datastore 100: -
The server (CentOS 7.2) running oned contains the aws-sdk (1.66.0) but my impression is that the code in /var/lib/one/remotes/market/s3/S3.rb expects an newer version of the gem. Version 1.66.0 is installed by the script /usr/share/one/install_gems.
The endpoint uses https with an official SSL cert.
The setup was done by a modified Puppet module epost-one v1.3. I’ve extended the templates for the oned, Sunestone and its views. The generated config files are matching a standard 5.0 beta rpm installation.
Regards jules (irc: #opennebula nick: wob)
