so it seems that opennebula 5.8.2 has been released on github for 26 days now but there are still no RPM packages available on Index of /repo/5.8/CentOS/7/x86_64 , what’s the planning on releasing these?
Thanks
Thanks
Hi Anton,
I’m trying to build from sources too, on CentOS 7, but I’ve got this error:
econe-stop-instances(1) -- Stops a set of virtual machines
/usr/share/rubygems/rubygems/core_ext/kernel_require.rb:55:in `require': cannot load such file -- AWS (LoadError)
from /usr/share/rubygems/rubygems/core_ext/kernel_require.rb:55:in `require'
from /tmp/tmp.tnCGC7iGih/lib/ruby/cloud/econe/EC2QueryClient.rb:25:in `<top (required)>'
from /tmp/tmp.tnCGC7iGih/bin/econe-stop-instances:32:in `<main>'
roff: ./econe-stop-instances.1
html: ./econe-stop-instances.1.html +man,toc
gem install aws doesn’t seem to fix that. Do you know what provides this AWS ? Not a big deal, it only concerns man pages. Who reads the doc anyway
And following the official documentation about building from sources, it is said to remove node_modules from public sunstone directory. But in the official rpm packages, they are still present. Which one is wrong ?
[ONE2][root@node01 ~]# rpm -ql opennebula-sunstone|grep node_modules|wc -l
5505
it’s a lot of files !
Best regards,
Edouard
Hi @madko
You should compile information from the docs, opennebula sources and the script that create the packages. The truth usually is somewhere between them :). Usually the procedure described in OpenNebula/packages repo and their scripts do the job. (But don’t forget to checkout the release of the packages that match OpenNebula’s release)
Hope this helps.
Best Regards,
I’m following information from https://github.com/OpenNebula/packages is that correct ?
here:
rm -rf node_modules/
So I don’t understand why those files are in the official RPM ?
should I open a ticket for that ?
There is also git://anongit.freedesktop.org/spice/spice-html5 in bower dependencies that is not a good idea. Because most of the companies are behind web proxies. So we are using this URL https://github.com/freedesktop/spice-html5 as an alternative.
Hi @madko,
If you feel something is not righ - just open an issue, the developers will followup with comments is this a bug or not
Best Regards,
