Is was wondering if anyone is using opennebula in combination with HP 3PAR storage nodes.
Would it be doable to create a custom driver.
Regards,
Vincent
Regards,
Vincent
Hi Vincent, did you step forward on your experiment with 3PAR?
I think that I have a similar problem to solve: I would connect the physical 3PAR device to different VMs using OCFS2.
Regards,
Mario
No, I was just curious if someone already build something. Currently it’s out of scope.
Vincent
I’ve made a configuration adding this option at the vm template (raw data):
<devices>
<disk type='block' device='disk'>
<driver name='qemu' type='raw' cache='none'/>
<source dev='/dev/mapper/to/phic/device' />
<target dev='vda' bus='virtio'/>
</disk>
</devices>
In this way the virtual machine can see the 3par device. After that, you can use ocfs2 filesystem for sharing the device in correct way.
Hi all, I know, it is four years ago you create this thread, but I like to tell you that we developed and open-sourced 3PAR storage driver for OpenNebula. [Contribution] HPE 3PAR Storage driver
