Opennebula installation
I need to use opennebula API to manage cloud resources ?
Is it possible to install opennebula front-end and node in a same single machine ?
My machines features are:
RAM=8Go
CPU= 2.50GHz × 4
Disk Space= 292.2 GB
Hello, you can run it in VM, so can be easilly migrated in future. Personally I have VM with 2xCPU, 8GB RAM and 20GB HDD.
@feldsam i couldn’t realize the the connection between my laptop and the VM so i can’t work with the API.
Do you have any idea how can i work with the API to develop applications?
Hello, them you should use sandbox https://opennebula.org/tryout/
@feldsam i used a sandbox but i couldn’t worl the API ?
Have you any idea about this?
