OpenNebula is not running or there was a server exception. Please check the server logs. please help
latest nebula from a few days ago
did some work, some imports, everything was fine
came by a few ours, started the system and boom : "OpenNebula is not running or there was a server exception. Please check the server logs. "
this is what comes out from status command
[root@console ~]# service opennebula status
Redirecting to /bin/systemctl status opennebula.service
● opennebula.service - OpenNebula Cloud Controller Daemon
Loaded: loaded (/usr/lib/systemd/system/opennebula.service; enabled; vendor p reset: disabled)
Active: failed (Result: exit-code) since Wed 2019-06-26 18:03:36 IDT; 17s ago
Process: 13701 ExecStopPost=/usr/share/one/follower_cleanup (code=exited, stat us=0/SUCCESS)
Process: 13697 ExecStopPost=/bin/rm -f /var/lock/one/one (code=exited, status= 0/SUCCESS)
Process: 13694 ExecStop=/bin/kill -TERM $MAINPID (code=exited, status=1/FAILUR E)
Process: 13688 ExecStart=/usr/bin/oned -f (code=exited, status=0/SUCCESS)
Process: 13684 ExecStartPre=/usr/sbin/logrotate -s /tmp/logrotate.state -f /et c/logrotate.d/opennebula (code=exited, status=0/SUCCESS)
Process: 13681 ExecStartPre=/bin/chown oneadmin:oneadmin /var/log/one (code=ex ited, status=0/SUCCESS)
Process: 13679 ExecStartPre=/bin/mkdir -p /var/log/one (code=exited, status=0/ SUCCESS)
Main PID: 13688 (code=exited, status=0/SUCCESS)
Jun 26 18:03:36 console.meshipc.co.il systemd[1]: Starting OpenNebula Cloud C…
Jun 26 18:03:36 console.meshipc.co.il systemd[1]: Started OpenNebula Cloud Co…
Jun 26 18:03:36 console.meshipc.co.il systemd[1]: opennebula.service: control…
Jun 26 18:03:36 console.meshipc.co.il systemd[1]: Stopped OpenNebula Cloud Co…
Jun 26 18:03:36 console.meshipc.co.il systemd[1]: Unit opennebula.service ent…
Jun 26 18:03:36 console.meshipc.co.il systemd[1]: opennebula.service failed.
Hint: Some lines were ellipsized, use -l to show in full.
i’m not sure where to look or what’s wrong. i’ve read some stuff and all sort of ideas but so far no go.
thank you
