Shashwatsh
(Shashwat Shagun)
October 27, 2017, 5:55am
#1
OpenNebula shows 117 GB total storage on shared filesystem when actual storage is 5 TB
OpenNebula:
DATASTORE CAPACITY
TOTAL: : 117.6G
FREE: : 106.7G
USED: : 4.9G
LIMIT: : -
df -l on host
/dev/mapper/vg0-root 5.5T 5.5G 5.2T 1% /
Could you please provide some more context?
Like version of OpenNebula, datastore configuration, OS, etc…
Are there error messages in the OpenNebula logs?
Best Regards,
Shashwatsh
(Shashwat Shagun)
October 27, 2017, 8:23pm
#3
@atodorov_storpool Version 5.4 stable , OS : ubuntu 16.04, datastore :- shared filesystem
Shashwatsh
(Shashwat Shagun)
October 27, 2017, 9:21pm
#4
@atodorov_storpool mM][I]: Command execution fail: /var/lib/one/remotes/tm/fs_lvm/monitor PERTX0RSSVZFUl9BQ1RJT05fREFUQT48REFUQVNUT1JFPjxJRD4xMTM8L0lEPjxVSUQ+MDwvVUlEPjxHSUQ+MDwvR0lEPjxVTkFNRT5vbmVhZG1pbjwvVU5BTUU+PEdOQU1FPm9uZWFkbWluPC9HTkFNRT48TkFNRT5sdm1fc3lzdGVtPC9OQU1FPjxQRVJNSVNTSU9OUz48T1dORVJfVT4xPC9PV05FUl9VPjxPV05FUl9NPjE8L09XT$ Fri Oct 27 17:18:44 2017 [Z0][ImM][I]: ExitCode: 255
Hi Shashwat Shagun,
You should check the configuration of the datastores. AFAIK the fs_lvm monitoring probe is not used for TM_MAD type shared .
Best Regards,
