After the opennebula installation, the ID0 system volume can not display the capacity, and the / var / lib / one / datastores / 0 permissions on the server are 754.Seeking to help solve the big gods, very grateful! . .
can you take a look at /var/log/one/oned.log and look for errors?
I think that if you are using ssh for TM_MAD the system datastore will be monitored after first VM is deployed there.
Not sure on 5.2 but on the I’ve have such oservation on older ONE versions.
Kind Regards,
