Opennebula try to monitor nonexisting volume groups
I am using LVM Block storage for IMAGE_DS and GFS2 for SYSTEM_DS, FILE_DS and IMAGE_DS. Problem is with monitoring scripts. For some time, lvm commands take too long time with errors like this:
Error locking on node X: Command timed out
So I try to investigate where is problem and I found locks on non existing volume groups in DLM.
Resource len 10  "V_vg-one-0"
Resource len 10  "V_vg-one-1"
Resource len 10  "V_vg-one-2"
When I look into running processes using htop I found that opennebula monitoring scripts are looking for that volume groups vg-one-0, vg-one-1, vg-one-2
See attached screenshots:
Why opennebula do this? In `/var/lib/one/remotes/datastore/lvm/lvm.conf I have setuped
# Default volume group
VG_NAME=vg-images
[oneadmin@engine1 ~]$ onedatastore list
  ID NAME                SIZE AVAIL CLUSTER      IMAGES TYPE DS      TM      STAT
   0 system           1023.9G 98%   feldhost          0 sys  -       shared  on
   1 default          1023.9G 98%   feldhost          5 img  fs      qcow2   on
   2 files            1023.9G 98%   feldhost          2 fil  fs      shared  on
 104 images              2.4T 25%   feldhost         30 img  lvm     lvm     on
 106 raid10              2.7T 63%   feldhost          0 img  lvm     lvm     on
[oneadmin@engine1 ~]$ onedatastore show 0
DATASTORE 0 INFORMATION
USER           : oneadmin
GROUP          : oneadmin
CLUSTER        : feldhost
TYPE           : SYSTEM
DS_MAD         : -
TM_MAD         : shared
BASE PATH      : /var/lib/one/datastores/0
DISK_TYPE      : FILE
STATE          : READY
DATASTORE CAPACITY
TOTAL:         : 1023.9G
FREE:          : 1006.2G
USED:          : 17.7G
LIMIT:         : -
OWNER          : um-
GROUP          : u--
OTHER          : ---
DATASTORE TEMPLATE
BASE_PATH="/var/lib/one/datastores/"
SHARED="YES"
TM_MAD="shared"
TYPE="SYSTEM_DS"
IMAGES
[oneadmin@engine1 ~]$ onedatastore show 1
DATASTORE 1 INFORMATION
USER           : oneadmin
GROUP          : oneadmin
CLUSTER        : feldhost
TYPE           : IMAGE
DS_MAD         : fs
TM_MAD         : qcow2
BASE PATH      : /var/lib/one/datastores/1
DISK_TYPE      : FILE
STATE          : READY
DATASTORE CAPACITY
TOTAL:         : 1023.9G
FREE:          : 1006.2G
USED:          : 17.7G
LIMIT:         : -
OWNER          : um-
GROUP          : u--
OTHER          : ---
DATASTORE TEMPLATE
BRIDGE_LIST="node1 node2 node3"
CLONE_TARGET="SYSTEM"
DISK_TYPE="FILE"
DS_MAD="fs"
LN_TARGET="NONE"
TM_MAD="qcow2"
TYPE="IMAGE_DS"
IMAGES
71
98
122
124
125
[oneadmin@engine1 ~]$ onedatastore show 2
DATASTORE 2 INFORMATION
USER           : oneadmin
GROUP          : oneadmin
CLUSTER        : feldhost
TYPE           : FILE
DS_MAD         : fs
TM_MAD         : shared
BASE PATH      : /var/lib/one/datastores/2
DISK_TYPE      : FILE
STATE          : READY
DATASTORE CAPACITY
TOTAL:         : 1023.9G
FREE:          : 1006.2G
USED:          : 17.7G
LIMIT:         : -
OWNER          : um-
GROUP          : u--
OTHER          : ---
DATASTORE TEMPLATE
DS_MAD="fs"
LN_TARGET="NONE"
TM_MAD="shared"
TYPE="FILE_DS"
IMAGES
77
81
[oneadmin@engine1 ~]$ onedatastore show 104
DATASTORE 104 INFORMATION
USER           : oneadmin
GROUP          : oneadmin
CLUSTER        : feldhost
TYPE           : IMAGE
DS_MAD         : lvm
TM_MAD         : lvm
BASE PATH      : /var/lib/one/datastores/104
DISK_TYPE      : BLOCK
STATE          : READY
DATASTORE CAPACITY
TOTAL:         : 2.4T
FREE:          : 610.3G
USED:          : 1.8T
LIMIT:         : -
OWNER          : um-
GROUP          : u--
OTHER          : ---
DATASTORE TEMPLATE
CLONE_TARGET="SELF"
DISK_TYPE="BLOCK"
DS_MAD="lvm"
LN_TARGET="NONE"
TM_MAD="lvm"
TYPE="IMAGE_DS"
VG_NAME="vg-images"
IMAGES
18
19
21
25
26
41
42
44
45
52
54
55
56
57
58
59
60
61
64
66
67
68
82
87
90
91
92
93
108
127
[oneadmin@engine1 ~]$ onedatastore show 106
DATASTORE 106 INFORMATION
USER           : oneadmin
GROUP          : oneadmin
CLUSTER        : feldhost
TYPE           : IMAGE
DS_MAD         : lvm
TM_MAD         : lvm
BASE PATH      : /var/lib/one/datastores/106
DISK_TYPE      : BLOCK
STATE          : READY
DATASTORE CAPACITY
TOTAL:         : 2.7T
FREE:          : 1.7T
USED:          : 1T
LIMIT:         : -
OWNER          : um-
GROUP          : u--
OTHER          : ---
DATASTORE TEMPLATE
CLONE_TARGET="SELF"
DISK_TYPE="BLOCK"
DS_MAD="lvm"
LN_TARGET="NONE"
TM_MAD="lvm"
TYPE="IMAGE_DS"
VG_NAME="vg-raid10"
IMAGES
We had same problem in our installation. Only solution i found is to comment out lines
if [ $? == 0 ]; then LVM_SIZE_CMD="sudo vgdisplay --separator : --units m -o vg_size,vg_free --nosuffix --noheadings -C" fi
in monitor_ds.sh. (Opennebula 4.12)
Thank you, looks like it is removed in Opennebula 5.0, so I update from 4.14 to 5.0.1.
