Hello, I am developing custom storage driver for HPE 3PAR and I have problems with monitoring VM DISK_SIZE. I already implemented VMs disk monitoring to TM_MAD monitor script. Oned sucessfully onitor VMs disks from system ds with 3par tm mad, but only after restart. On next monitoring cycle it doesn’t monitor VMs disk sizes from response of tm monitor script.
here is log, where we can see, that first time it monitor disk size using system ds tm monitor script and next time it use data from host probe monitoring script.
Thu Dec 20 20:25:00 2018 [Z0][ImM][D]: Datastore 3par_system (0) successfully monitored.
Thu Dec 20 20:25:00 2018 [Z0][VMM][D]: VM 57 successfully monitored: DISK_SIZE=[ID=0,SIZE=1366] DISK_SIZE=[ID=1,SIZE=506]
Thu Dec 20 20:25:00 2018 [Z0][VMM][D]: VM 58 successfully monitored: DISK_SIZE=[ID=0,SIZE=1366] DISK_SIZE=[ID=1,SIZE=506]
Thu Dec 20 20:25:00 2018 [Z0][VMM][D]: VM 67 successfully monitored: DISK_SIZE=[ID=0,SIZE=1283]
Thu Dec 20 20:25:07 2018 [Z0][InM][D]: Monitoring host tst.lin.fedora.host (0)
Thu Dec 20 20:25:11 2018 [Z0][ReM][D]: Req:7552 UID:0 one.zone.raftstatus invoked
Thu Dec 20 20:25:11 2018 [Z0][ReM][D]: Req:7552 UID:0 one.zone.raftstatus result SUCCESS, "<RAFT><SERVER_ID>-1<..."
Thu Dec 20 20:25:11 2018 [Z0][ReM][D]: Req:2624 UID:0 one.vmpool.info invoked , -2, -1, -1, -1
Thu Dec 20 20:25:11 2018 [Z0][ReM][D]: Req:2624 UID:0 one.vmpool.info result SUCCESS, "<VM_POOL><VM><ID>57<..."
Thu Dec 20 20:25:11 2018 [Z0][ReM][D]: Req:6128 UID:0 one.vmpool.info invoked , -2, -1, -1, -1
Thu Dec 20 20:25:11 2018 [Z0][ReM][D]: Req:6128 UID:0 one.vmpool.info result SUCCESS, "<VM_POOL><VM><ID>57<..."
Thu Dec 20 20:25:11 2018 [Z0][InM][D]: Host tst.lin.fedora.host (0) successfully monitored.
Thu Dec 20 20:25:11 2018 [Z0][VMM][D]: VM 57 successfully monitored: DISK_SIZE=[ID=0,SIZE=0] DISK_SIZE=[ID=1,SIZE=0] DISK_SIZE=[ID=2,SIZE=1] STATE=a CPU=0.0 MEMORY=786432 NETRX=92940 NETTX=67780 DISKRDBYTES=141090628 DISKWRBYTES=25890816 DISKRDIOPS=6961 DISKWRIOPS=2106
Thu Dec 20 20:25:11 2018 [Z0][VMM][D]: VM 58 successfully monitored: DISK_SIZE=[ID=0,SIZE=0] DISK_SIZE=[ID=1,SIZE=0] DISK_SIZE=[ID=2,SIZE=1] STATE=a CPU=0.0 MEMORY=786432 NETRX=94955 NETTX=71326 DISKRDBYTES=143212356 DISKWRBYTES=26133504 DISKRDIOPS=7041 DISKWRIOPS=2147
Thu Dec 20 20:25:11 2018 [Z0][VMM][D]: VM 67 successfully monitored: DISK_SIZE=[ID=0,SIZE=0] DISK_SIZE=[ID=1,SIZE=1] STATE=a CPU=0.0 MEMORY=786432 NETRX=106169 NETTX=139249 DISKRDBYTES=1408790340 DISKWRBYTES=1732886528 DISKRDIOPS=312972 DISKWRIOPS=420742
so I look at system datastore filesystem on host and removed .monitor file, so I disable local monitoring.
after oned restart it collects right data from system ds tm monitor script, but only first. No more VMs disk sizes monitor in next monitoring cycles…
Please help. Thanks
) on 3par you should take a lok what I am changing there too (total hijack).
