Opennebula with NAS storage
Hello All,
I am new to opennebula, I am trying to setup a lab environment with NAS storage.I am struggling to bringup a VM.Here is my setup
  1. I have installed frontend and did NFS mount /var/lib/one/datastores from NAS storage where I also have some old images
  2. on the node I have NFS /var/lib/one/datastores
  3. Create image using the source from old Windows Server which is located /var/lib/one/datastores/images
  4. Created VM Template and VM
Once you bring up VM it fails with the following error
Fri Oct 4 23:21:22 2019 [Z0][VM][I]: New state is ACTIVE
Fri Oct 4 23:21:22 2019 [Z0][VM][I]: New LCM state is PROLOG
Fri Oct 4 23:21:23 2019 [Z0][VM][I]: New LCM state is BOOT
Fri Oct 4 23:21:23 2019 [Z0][VMM][I]: Generating deployment file: /var/lib/one/vms/9/deployment.0
Fri Oct 4 23:21:25 2019 [Z0][VMM][I]: Successfully execute transfer manager driver operation: tm_context.
Fri Oct 4 23:21:25 2019 [Z0][VMM][I]: Successfully execute network driver operation: pre.
Fri Oct 4 23:21:26 2019 [Z0][VMM][I]: Command execution fail: cat << EOT | /var/tmp/one/vmm/kvm/deploy ‘/var/lib/one//datastores/100/9/deployment.0’ ‘192.168.1.xxx’ 9 192.168.1.xxx
Fri Oct 4 23:21:26 2019 [Z0][VMM][I]: error: Failed to create domain from /var/lib/one//datastores/100/9/deployment.0
Fri Oct 4 23:21:26 2019 [Z0][VMM][I]: error: internal error: qemu unexpectedly closed the monitor: che=none -device ide-hd,bus=ide.0,unit=0,drive=drive-ide0-0-0,id=ide0-0-0,bootindex=1,write-cache=on -drive file=/var/lib/one//datastores/100/9/disk.1,format=raw,if=none,id=drive-ide0-0-1,readonly=on -device ide-cd,bus=ide.0,unit=1,drive=drive-ide0-0-1,id=ide0-0-1 -vnc 0.0.0.0:9 -device cirrus-vga,id=video0,bus=pci.0,addr=0x2 -device virtio-balloon-pci,id=balloon0,bus=pci.0,addr=0x3 -sandbox on,obsolete=deny,elevateprivileges=deny,spawn=deny,resourcecontrol=deny -msg timestamp=on
Fri Oct 4 23:21:26 2019 [Z0][VMM][I]: 2019-10-07 23:01:43.400+0000: Domain id=1 is tainted: high-privileges
Fri Oct 4 23:21:26 2019 [Z0][VMM][I]: 2019-10-07T23:01:43.531171Z qemu-kvm: -drive file=/var/lib/one//datastores/100/9/disk.0,format=qcow2,if=none,id=drive-ide0-0-0,cache=none: Could not open ‘/var/lib/one//datastores/100/9/disk.0’: Permission denied
Fri Oct 4 23:21:26 2019 [Z0][VMM][E]: Could not create domain from /var/lib/one//datastores/100/9/deployment.0
Fri Oct 4 23:21:26 2019 [Z0][VMM][I]: ExitCode: 255
Fri Oct 4 23:21:26 2019 [Z0][VMM][I]: Failed to execute virtualization driver operation: deploy.
I would appreciate if anybody can help with this
Check your NFS share permissions. Check if user oneadmin has all the rights on the node.
Thanks Branislav,
I have looked at the permissions here is what I have
lrwxrwxrwx. 1 oneadmin oneadmin 51 Oct 7 2019 /var/lib/one/datastores/100/9/disk.0 -> /var/lib/one/datastores/images/windows2012_ad.qcow2
when I look at the actual file windows2012_ad_qcow2 it is owned by nfsnobody, do you think that is the problem
Yes looks correct. Try to create and remove files and folders on system and images datastores. Try on front end and node.
