Since we have updated our testing cluster to OpenNebula 4.14.2 we have notice a issue trying to instantiate a template which contains FILES_DS values into CONTEXT, here is our template:
And now we get this error from ONE using oneadmin user:
$ onetemplate instantiate 1 --name test
[TemplateInstantiate] Error allocating a new virtual machine. Error parsing: run_user_script.sh. syntax error, unexpected RSTRING, expecting VARIABLE at line 1, columns 1:19
It was working before, it seems that OpenNebula is trying to parse the bash script and it fails… Do you known if this is a known issue or if we should change FILES_DS by another value?
I have similar issue bu it was due to a bug in 4.14.0. IMO FILE_DS should contain index to the file in the files datastore and INIT_SCRIPTS must have the name of the scripts that should be called. Here is an example where i have uploaded set-root-password.sh in the FILES datastore and it has ID 18,
The onedb tool doesn’t change the FILES_DS attribute, and the parser hasn’t been touched lately…
What OpenNebula version were you using before? Are you sure that exact same template was working?
We did a minor update from 4.14.0 to 4.14.2 but at this moment I’m not sure how or when it was modified, (probably it was modified by a human being ). In any case I will try to reproduce the issue, but nothing to be worried about, sorry for the noise…
Thanks a lot for the info! This is a test machine and its updated frequently so I was not sure when it was modified. I didn’t found any issue running 4.14.2 either
