I just tried to create custom context attribute foo with the value $UNAME_foo, but in shell scripts, I must delimit the variable with ${UNAME}_foo.
Unfortunately, doing so in Sunstone result in a parse error of my template, and $UNAME_foo results in the foo attribute` not present in context.
Should I open a bug report or is there a way to achieve my goal?
Regards.
