On instantiating an ubuntu based VM using the opennebula supplied firecracker kernel, I get the following error:
Wed Mar 13 15:06:44 2024 [Z0][VMM][I]: Failed to execute virtualization driver operation: deploy.
Wed Mar 13 15:06:44 2024 [Z0][VMM][E]: DEPLOY: error: Failed to create domain from /var/lib/one//datastores/0/31/deployment.0 error: internal error: qemu unexpectedly closed the monitor: 2024-03-13T15:06:43.512284Z qemu-kvm-one: Error loading uncompressed kernel without PVH ELF Note Could not create domain from /var/lib/one//datastores/0/31/deployment.0 ExitCode: 255
Wed Mar 13 15:06:44 2024 [Z0][LCM][E]: deploy_failure_action, VM in a wrong state
Wed Mar 13 15:07:14 2024 [Z0][LCM][I]: VM running but monitor state is POWEROFF
Wed Mar 13 15:07:14 2024 [Z0][VM][I]: New LCM state is SHUTDOWN_POWEROFF
Wed Mar 13 15:07:14 2024 [Z0][VM][I]: New state is POWEROFF
Wed Mar 13 15:07:14 2024 [Z0][VM][I]: New LCM state is LCM_INIT
Kernel: Kernel 5.4 x86_64 - Firecracker
Disk: ubuntu 22.04 image
Rerun template
Failed
VM running
I cannot find many details as to the KVM_CPU_FEATURES that could be added to the template and not sure if possible whether these should be set at ths VM or HOST or BARE METAL LEVEL
