Hi all,
I recently configured GlusterFS cluster as a datastore. Everything is OK, but Virtual Machine Definition File (deployment file) do not contain glusterfs protocol in disk section.
It deploys VMs like this. -
disk type=‘file’ device=‘disk’>
source file=‘/var/lib/one//datastores/112/25/disk.1’/>
target dev=‘hdc’/>
driver name=‘qemu’ type=‘raw’ cache=‘none’/>
/disk>
Despite it works and I can install and use VM, i would like to fix that so VM disks will be deployes as gluster protocol disks. So like this -
<disk type='network' device='disk'> <source protocol='gluster' name='/25/disk.2'/> <target dev='hda'/> <driver name='qemu' type='raw' cache='none'/> </disk>
what should I fix ?
Thanks
