I accidentally deleted the default images datastore which had id 1. How can I re-create it?
Regards
Christoph
Regards
Christoph
Did you delete the datastore from OpenNebula? In that case, you can create a new datastore since they were not images registered there.
If you delete the datastore from the disk, unfortunately there is no way to recover the images registered.
