Recover vms stuck in UNKOWN state
We upgraded our cluster from 5.10 to 5.12. We mistakenly had a few hosts that were downgraded back to 5.10.
Even after re-upgrading those KVM hosts to 5.12, the VMs on those host are stuck in UNKOWN state.
How do we recover these VMs?
Answer
We recovered 90% of the vms by running the followiong on the opennebula node
sudo -u oneadmin onehost sync --force
To recover the vms on a specific host, add the host ID
vms=$(onevm list --csv | grep unkn | tail -n 1)  #Picks a single VM stuck in UNKNOWN state
vm_id=$(echo $vms | awk '{split($0,a,","); print a[1]}' )
vm_name=$(echo $vms | awk '{split($0,a,","); print a[4]}' )
kvm_name=$(echo $vms | awk '{split($0,a,","); print a[8]}' )
echo $vm_id
echo $vm_name
echo $kvm_name
sudo -u oneadmin onehost sync $kvm_name --force
For the remaining vms we did the following
  1. Ensure the host is enabled
onehost enable $kvm_id # you can get the id with 'onehost list'
onehost show $kvm_id | grep 'STATE\|LAST' # Wait until this transisions from INIT to MONITORED
  1. Restart libvirt-bin on the kvm host
sudo service libvirt-bin restart
  1. Re-run the sync on the nebula host
If the host still isn’t updating, Try killing the monitord process, removing the pid and then forcing a resync.
# On host
ps aux | grep monitord
kill <pid of monitord>
rm /tmp/onemonitord-<hostid>.error
rm /tmp/one-monitord-<hostid>.pid
# On OpenNebula
onehost enable <hostid>
sudo -u oneadmin onehost enable <hostid> --force
sudo -u oneadmin onehost forcesync
If this doesn’t resolve the issue try the following
# On KVM host
mv /var/tmp/one /var/tmp/one.backup
We did have a few hosts that took a couple of sync attempts to to fix
onehost enable 72
sudo -u oneadmin onehost sync 42 --force
Should be
sudo -u oneadmin onehost sync <hostid> --force
