Hello, I’m developing the disk hotplug for LXDoNe and I’m in a roadblock. The thing is, attach_disk modifies the VM template, but doesn’t update the deployment.X file which contains the xml. You can request the VM template in the frontend and dump it into a file, that is nice, but, what I really need is to do the same thing in a virtualization host. I haven’t found a way to do this.
Is it the same format like the one provided by deploy? I had read the integration guide and it seemed to me that the xml was only related to the new disk. Can you confirm this?
